mbacis
Which would you recommend to drive two Infinity Kappas (75W RMS) and one ID8 (175W RMS)?
Bazooka EL460
65 watts RMS x 4 at 4 ohms
85 watts RMS x 4 at 2 ohms
175 watts x 2 in bridged mode
2-, 3-, or 4-channel output
Tri-Way capable
Variable high-pass/low-pass crossover, 12 dB per octave
MOSFET output devices
Variable bass boost
Output port for easy connection of Bazooka EL-series amplified bass tube
Speaker-level and preamp-level inputs
Dimensions: 14-21/64"W x 2-21/32"H x 10-1/4"D
Clarion APA450
Amplifier Type: Multi-Channel
RMS Power @ 4 Ohms: 50W x 4 @ 14.4V
THD at 4-Ohm RMS Power: 0.1 %
Bridged RMS Power @ 4 Ohms: 200W x 2 (maximum)
Speaker Level Inputs: Yes
Preamp Outputs: No
Built-In Crossovers: HP/LP
Bass Boost: 0, 6, 12 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: n/a
Fuse Rating: n/a
Profile CL640
RMS Power Output (Watts x Channels) 75 x 4
Frequency Response N/A
THD at Rated RMS Power 0.07%
Signal to Noise Ratio 105 dB
Input Voltage 14.4v
Peak Power Output (Watts x Channels) 150 x 4
Power at 2 Ohms (Watts x Channels) 110 x 4
Bridged Power (Watts x Channels) 225 x 2
Minimum Impedance Bridged 4
Minimum Impedance Unbridged 2
Features
Amplifier Class AB
Tri-Mode Capable Yes x 2
Low-Pass Crossover Frequency 40-500 Hz
Low-Pass Slope (dB/octave) 12 dB
High-Pass Crossover Frequency 40-500 Hz
High-Pass Slope (dB/octave) 12 dB
Bass Boost 0-18 dB
Bass Boost Frequency 45 Hz
Fan Cooled No
Fuse Rating 25 x 2
Speaker Level Inputs Yes
Preamp Outputs 1 pair
LED Power Indicator Yes
Height (inches) 2-5/8
Width (inches) 14-9/16
Length (inches)
Or, feel free to recommend others in the $100-$150 shipped range.
Bazooka EL460
Tri-Way capable
Variable bass boost
Clarion APA450
Preamp Outputs: No
Fuse Rating: n/a
Profile CL640
Input Voltage 14.4v
Features
Amplifier Class AB
Bass Boost 0-18 dB
Fan Cooled No
Fuse Rating 25 x 2
Length (inches)
