DaBaller504
Livin Loud In Da Blazer
Which one do you think will give me more power?
Like which one actually has more true wattage?
Preferibly people who have used Lanzar
The Opti Drive 1000
1000 Watts x 1 @ 1 Ohm
Class "D" Design
Extremely Fast Switching Power Circuits
Super High Current Output Stages Using
Multiple High Current MOSFET's
Independent 24 dB Per Octave
Hi & Low Pass
Wired Bass Jack
Adjustable Gain Control
Variable Bass Control
4 Inputs Mixed to Mono For
Front/Rear Fading
1 Line Level Output For Brodging
2 OptiDrive Class "D" Amps Together
Variable Phase Shift
Variable Base Boost
The 1500D
1 x 400 Watts RMS at 4 Ohms
1 x 800 Watts Max at 2 Ohms
1 x 1500 Watts Max at 1 Ohms
Mono Block Subwoofer Amplifier
1 Ohm Stereo Stable
MOSEFT Power Supply
PMW (pulse-Width-Modulation) System
Glass Epoxy PCB
Custom Terminal Block for Speaker Connection
Thermal, Overload & Short Protection
Variable Subsonic Filter (15Hz-50Hz, 24dB/Octave)
Variable Lowpass Filter (50Hz-250Hz, 24dB/Octave)
Remote Bass Control
Input Impedance: 10k Ohms
VU Meter
Thermometer
Heavy Duty Power Coated Heatsink
Frequency Response: 15 Hz-35 kHz
S/N Ratio: 90 dB
Dimensions: 10.95 W x 2.3 H x 15 L
The Opti Drive 1000
Class "D" Design
Hi & Low Pass
Wired Bass Jack
Front/Rear Fading
Variable Base Boost
The 1500D
1 Ohm Stereo Stable
MOSEFT Power Supply
Glass Epoxy PCB
Remote Bass Control
VU Meter
Thermometer
S/N Ratio: 90 dB
