Hey i have two amps in mind
Kenwood KAC-X541 4- channel 960 watts max (60 watts RMS per channel) = $999
Pioneer GM-6100F 4-channel (60 watts RMS per channel) = $469
why is there a big price difference?
these are the specs i got..but didn't fully understand them
Kenwood
Pioneer
Kenwood
Features Highlights Maximum Output Power: 960W
Built in Parametric EQ Control
AMP Information Display (Voltage, Current, Temprature, Cooling Fan Speed)
Built-in Variable Low-pass/ High-pass Filter
Built-in Infrasonic Filter
Gold Plated Input/Output Terminals
Line Output Terminals (RCA) for Extension
2-Speed Cooling Fan
Detachable Aluminium Dress Plate
General Features
AMP Control System (8 AMPs Max. Connectable & Controllable with '04 Kenwood H/U*)
Bass Frequency Control (60/ 80/ 100/ 200Hz)
Bass Level Control (-15 to 15dB)
Bass Q Factor Control (1.00/ 1.25/ 1.5/ 2.0)
Treble Frequency Control (10.0k/ 12.5k/ 15.0k/ 17.5kHz)
Treble Level Control (-15 to 15dB)
5L Input for AMP Control Connection (H/U to AMP, with Optional CA-C6SH)
S-video Cable Input/Output Terminals for Amp Control Connection (AMP to AMP)
Variable Input Sensitivity (0.2-5V)
Built-in Variable Low-pass Filter 50-200Hz (24dB/oct) : B-channel
Built-in Variable High-pass Filter 50-200Hz (12dB/oct) : A/B-cahnnel
Built-in Infrasonic Filter 15Hz (24dB/oct) : B-channel
2-Speed Cooling Fan
Size: W 446mm x H 61mm x D 259.5mm (W/O Dress Plate)
Rated Output Power (14.4V)
60W x 4 at 20-20kHz 0.05%THD (4 Ohms)
120W x 4 at 1kHz 0.5%THD (2 Ohms)
240W x 2 at Bridged 1kHz 0.5%THD (4 Ohms)
Rated Output Power (12.0V)
45W x 4 at 20-20kHz 0.05%THD (4 Ohms)
90W x 4 at 1kHz 0.5%THD (2 Ohms)
180W x 2 at Bridged 1kHz 0.5%THD (4 Ohms)
Pioneer
Maximum Power Output
120 Watts x 4 or 300 Watts x 2 or 120 Watts x 2 + 300 Watts x 1
Maximum power output (EIAJ)
Continuous Power Output - Watts RMS
@ 14.4V (20 ~ 20kHz into 4 ohms) 60W x 4 (0.2%)
(20 ~ 20kHz into 2 ohms) 75W x 4 (0.8%)
Bridged into 4 ohms 150W x 2 (0.8%)
@ 12.0V (20 ~ 20kHz into 4 ohms) 605W x 4 (0.2%)
CEA2006 Amplifier Ratings
Power Output in Watts RMS @ 14.4 Volts
4 ohms @
2 ohms @
Bridged into 4 ohms @
Signal-to-noise Ratio 80dBA
Dynamic Power 60W @ 4 ohms
Specifications & Features
RCA and Speaker Level Input
Speaker Level Input (0.8V ~ 26Volt)
RCA Input (200mV - 6.5Volt)
LPF (Low Pass Filter) 80Hz, -12dB/oct.
HPF (High Pass Filter) 80Hz, -12dB/oct.
Frequency Response 10 ~ 50,000 Hz (+0db, -1dB)
Total Harmonic Distortion (THD)
Signal to Noise (S/N) Ratio > 95dB
Load Impedance per channel 2 ohms ~ 8 ohms
Separation (@1Kz): 70dB
Average Current Consumption (4 ohms, 4-Channels Driven): 9.0A
PWM Regulated Power Supply with MOSFET switching
Full Range RCA output
Screw-type power / ground / speaker terminals
High performance balanced isolator circuit
Amplifier Fuse Rating 25 Amps x 2
Amplifier Dimensions
300 x 60 x 327mm
Mass 4.7kg
