which on and why?
yes they are response curves, both slightly altered from the manufacturors recommendations cuz they were off and the peak was too much....the white one is the present, the blue one is smthg im thinking
still need some more details man... is this an SPL install or daily install?
i still say they look like absolute crap... not to mention that you should only be using winisd to get a slight idea of the results, and after that you should immediatly forget everything that winisd tells you.
so you would rather have a peaky 50-60hz instead of a smooth curve?
plus I have found just beacause it models up that way doesnt mean thats the way its going to go in car.
a smoth curve is not an option for this driver cuz it has a 24bd/otc drop at 50 anyways(vented) and a 12 db/oct in sealed..the vented version plays good on the 36mafia and all that shit tho, just thought id try the bandpass
yes its a peaky 50-60 Hz but wheres the point in tunning a bandpass lower?
where are you seeing a smooth curve? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
he has a curve thats about 5db up at 50Hz, and another that is about 8-9Db up at nearly 70Hz...
ok in relation to the curve that seems to look like everest. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
mile098
ohhh noeeeesss
mile098
dubrovnik, CROATIA
IamDeMan
