Which of the T/S Parameters show wat kind of box to use?
EBP:
taking the driver free air resonance (Fs) and dividing it by the electrical Q (Qes). If the resulting number is around 50 or less, you are looking at a driver that is best suited to a sealed type box. If the EBP is between 50 and around 100 or more, the speaker will work best in a vented enclosure. Horn loaded designs will perform best with an EBP of 150 or even higher.
Sealed box (and sealed bandpass) woofers should have the following characteristics:
Qts => 0.40
Fs
Xmax => 4 mm
Vented or ported box (and ported bandpass) woofers should have the following characteristics:
Qts
Fs
Vas should be relatively low (less than 4 cubic feet unless enclosure size is not a factor).
flakko
Veteran (my butt)
flakko
So Cal
PowerNaudio
