where the hell...
if a tiburon specific forum can't help you, I dont know what else to suggest.
just contact some folks that provide custom ho alts, theyll be able to help you, or at least point you in the right direction
would a 110 amps be enough for that amp? and the amp is rated at 4000 watts @ 1 ohm @ 17volts... how the hell do i get 17 volts? i really just want 13 though
If you don't know how to get 17 volts then chances are you don't need it lol. Contact any of the High Output Alt manufacturers as Savage said and they will work something out for you. That's really all anybody in here can tell you to do.
haha i upgraded from newb a long time ago but electrical is still one of my weak points. My 4 12 CVR's have a final load of 1 OHM and i think the amp is going to be overkill but i got a good deal on it.
If i dont wire it into 1 ohm i can go with 4 ohms and the amp says it puts out 2500 at 4 ohms on 17 volts and i also heard the major defect is these amps blow real easy on low voltage. I dont want that to happen. I think im gonna pick up a yellow top for the front when i get the alt.
Anything else recemended for my electrical that i should consider other than alt, batt and 0 gauge?
you seem to be worried about the 17 volt rating when 98% of people need to only worry about the 12-14volt ratiing. like said above chances are if you dont have any idea how to get 17+volt you do not have a system that needs that sort of power. get yourself a nice150-200 amp alt run it at 14.4 (stock voltage) and you will get plenty for the subs you are running. run a line of 0awg, a good ground, upgrade your big3 and maybe if you have the cash toss in an extra battery in the back. give it a shot. if you have voltage drops then look into other upgrades but my guess is you will not need it.
ravens9322
ravens9322
Lancaster, PA
ampresearch
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
