What's this button for?
when the button is pushed down, it decreases the db by 3, to lower the sound incase you dont like too much highs
maybe i got it mixed up, you can figure it out, push it down and you will hear the get louder or a little quiter.. not much difference
sorry if i got it flip flopped, havnt had experience with infinitys
put them on whatever sounds better, really it doesnt add is subtracts ie. +3 is really 0, and 0 is -3,
This.
It adjusts the tweeter level to -3 or flat. Which ever sound you prefer. If your tweeters are far away and you usually listen at low levels you will prefer the 0 (+3) setting.
If you tweeters are near your face or you usually listen at high volume, you will probably prefer the -3 setting (0 DB).
it attenuates them ( makes them louder )
do you even know what that word means?
From Dictionary.com..
at⋅ten⋅u⋅ate   /v. əˈtɛnyuˌeɪt; adj. əˈtɛnyuɪt, -ˌeɪt/ Show Spelled Pronunciation [v. uh-ten-yoo-eyt; adj. uh-ten-yoo-it, -eyt] Show IPA verb, -at⋅ed, -at⋅ing, adjective
–verb (used with object) 1. to weaken or reduce in force, intensity, effect, quantity, or value: to attenuate desire.
2. to make thin; make slender or fine.
3. Bacteriology, Immunology. to render less virulent, as a strain of pathogenic virus or bacterium.
4. Electronics. to decrease the amplitude of (an electronic signal).
–verb (used without object) 5. to become thin or fine; lessen.
–adjective 6. weakened; diminishing.
7. Botany. tapering gradually to a narrow extremity.
Origin:
1520–30;
This.
Thanks this is exactly what happens, and I like my tweeters to sizzle like sunday morning bacon, ummmm....!
Annao2485
Annao2485
Odessas, TX.
bamaster
