What you think?
i3abyjay25
Get F'n Loud
Is it too big?
Sat after work, i went to a friends house and started to build on my wall...
heres where i ended up at....
[/img]
[/img]
the box is 14.95 cu ft... but w/ sub and port displacment and bracing, it comes to be 9.6 cu ft
port is 31.5 x 6 = 189 sq in port.... tuned to 35 Hz
this was my 1st attempt at a wall inwhich i learned alot of things i should have done and shouldnt have done...
Should have stacked the subs on top of each other instead of staggering them like that. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif There's a TON of other things that could be changed too, but you'll catch on to things when you start fiddling around with different sizes/layouts.
Looks good for a first attempt though.
You should try facing the subs towards the rear of the vehicle, might be louder.
//content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif :rotflol: //content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif you should never speak about installs ever again....
Throw some threaded rod in there...
Play around with some angles inside...you'll teach yourself a lot //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i3abyjay25
Get F'n Loud
i3abyjay25
Dallas, Georgia
revrider1
