What would you do?
pics?
i would try to corner-load the port and sub. whatever configuration that yields. each orientation will change the actual tuning at the mic location. so your peak frequency will likely be different with each configuration.
your ears are terrible instruments. and if you can tolerate the level, you aren't that loud anyway. no offense, truf.
pics?
Thats one thing I'm worried about, I'm not going to have a chance to recheck the peak. Ill post a pic when the sun comes up if your around in the AM.
So you got a new box and no more flat playing 6th order?
And you're still only doing 146.4 with it? Or was that your old score and you havent metered the new box? If you get there early enough, most shows should have a test and tune or clinical where you can pay $5-10 and you can mess around with a meter for a little bit, I would try and do that, or hope someone else at the show has a meter that you could test with before you make your official run.
LosIsATool
LosIsATool
Pensacola, Florida
CAT MAN
