what #s are you shooting for?
well i play around 155 on music.... i want a lot more... designs for my setup are geared to being loud but musical...
i want more... and in january i am planning on making some orders and doing some upgrades //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
oh... so far my only burps i have tried have been at 24 Hz when i finished sealing the front loading chamber off i found out my peak dropped to 24Hz.... but the burps at that have been consistent 153.7's so far... just need more batt reserves...
24hz is rediculous... did you test that with the windows down or outlaw?
because with my windows down i can pick up the lowest of lows. even with the windows up. but i burp at 43 hz, although thats the only frequency i have tried.
i have done a 149.9 bass race and went over to 150. with on 5k goliath at 1 ohm
i have burped a 151.7 sealed on the glass with one goliath 5k at 1 ohm
i have burped a 152.7 in the kick with one goliath 5k at 1ohm
burped a 153.9 with one 5k goliath at .25 ohms
burped a 155.2 with 2 goliaths sealed on the glass at .5ohms each
and a 156.3 with 2 goliaths in the kick at .5 ohms.
i am hoping for a 162 with a shorter port and new amp.
24hz is rediculous... did you test that with the windows down or outlaw? because with my windows down i can pick up the lowest of lows. even with the windows up. but i burp at 43 hz, although thats the only frequency i have tried.
HOPE TO ALSO DO OVER A 160 SLAPPING MY KAWK OFF YOUR FOREHEAD //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
that was on the dash.
if you think just changing a port real quick and doing a new amp is gonna put you at 162... //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
i know ppl who have been trying for a very long time to do 160... it takes a lot of work... and unless you use a box built for farts, typically you dont do so hot.... typically...
im running 2 sd16ks to 4 18s with 8 layer flatwound aluminum coils. with a port 25inches shorter than my current.
i have already hit 155.2 and only tested 2 times. thats it. with a 2nd goliath that was 25% powered as it smoked the entire comp.
i know its a big number, but i also have built big.
sub-FATHER
Resurecting this sport
sub-FATHER
denver, CO.
S.B.C.
