What is?
What saying hifonics over rate their power...that's a real thing but it doesn't make an amp bad...I was running a vfl rated at 4500w but really did about 1200...It was a decent amp and did what I needed...so no I didn't insult his gear...saying an amp doesn't make rated isn't an insult...calling it pyramid type crap is though 😉
Give it up, bud. You can't change history, and your spin isn't working.
Says the guy who does NOTHING but repost links of conspiracy-laden crap.
A challenge: Drop the conspiracy links for a day and be a part of the conversation.
Can you do it?
Your previous post. Using homosexuality as if it is some type of insult.
Same crap Thxone pulls (meanwhile ironically obsessing on homosexual acts and male genitalia).
That doesn't prove I'm bigoted in anyway...that's circumstantial at the very best...try harder and don't let your feelings get in the way this time 😉
You thinking that it's an insult to call someone gay is not being bigoted in any way?
Interesting.
If you're not bigoted or biased against homosexuality, why would you consider it an insult?
Don't backpedal or try to spin, just answer the question directly.
Interesting.
So what you're saying is you have zero hard evidence to back up your accusations...good to know 🤭
I have your posts. Would you like to see them?
And I guess you are not bigoted against Nazis then, either. You use the terms "grammar nazi" and "nazi fan" as insults. But since using a term as an insult doesn't indicate bias or bigotry, then you must be OK with Nazis.
Right?
The spin should be interesting.
Right?
So now you're using nazis to prove your point 🤣🤣🤣
To prove the point that you are bigoted against something when you use that something as an insult.
But since you claim the opposite, then logic says you have no problem with Nazis.
A weird stance to take. Maybe if you had learned about that whole WWII thing in history class...
Clifff150
Clifff150
Texas
administrator
