What is?
I saw that, but that’s not correct, I don’t think. He goes over the study in the video in detail, man. There’s also a ton of censorship. There’s been tons of problems with this vaccine, and since they didn’t do long term safety studies, new results are still popping up. Multiple studies show a relationship between the covid vaccines and new or or worsening neuro problems, and just because that one site isn’t making sense atm doesn’t mean it’s not true. There is censorship where I can’t find some studies depending on what search engine I use, that may play a role in this. You’re just gonna hang on this one thing and not look at the rest of the info that backs it. That study is real and happened.
He's using the same source you're original article cited. Just because the source is f'd doesn't mean the narrative is - that's a good one. Can I use that the next time you say something about the liberal media?
Like I said when these guys start talking about how Covid is causing all these same side effects only at a much higher percentage, then I'll consider them to be telling the truth. When these guys start mentioning that these side effects are immune responses and have been documented in numerous other vaccines, then I'll take them seriously. Hell your (and his) source actually link to a study about how Covid causes MS. They're misrepresenting the facts by telling you less than half the truth and maybe half the truth is good enough if you've already made up your mind or have some agenda to push. I tend to like to see a more complete set of facts and then form an opinion. You're welcome to do as you like.
Like I said when these guys start talking about how Covid is causing all these same side effects only at a much higher percentage, then I'll consider them to be telling the truth. When these guys start mentioning that these side effects are immune responses and have been documented in numerous other vaccines. Hell your (and his) source actually link to a study about how Covid causes MS. They're misrepresenting the facts by telling you less than half the truth and maybe half the truth is good enough if you've already made up your mind or have some agenda to push. I tend to like to see a more complete set of facts and then form an opinion. You're welcome to do as you like.
He goes into it properly.
Or you could research more. There’s a reason why some amount of people have adverse reactions to the Covid vaccine. There’s specific immune system responses to the spike protein and functioning of the vaccine that causes the body to attack the nervous system. It’s a trend of the same pattern where the spike protein and immune system response to the spike making it to certain parts of the body causes damage to those parts of the body, including the nervous system (and heart). The MS study falls in line with those other problems.
There's your problem.i never saidyou could...but you're happy to falsely accuse me of it...truth doesn't matter if you're "smart"...right Rob 😉.
If you’re going to say im wrong when I say a mono amp cannot be bridged or have multiple outputs, then you are by default saying those things CAN happen. And you would be wrong
Of course if you say I’m correct, then you are by default saying your boy Thxone is wrong.
Quite the pickle you’ve put yourself in.
Just for the idiot... because he needs to learn.
Solder Bridge:
Speaker Terminal Bridge:
Dual mono amp circuit:
What is your point? That dual mono amps exist? No one here ever said they didn’t.
I used to sell penta mono amps. Each one had a single output, because a mono amp will only ever have ONE output.
By your strict use of terminology that only you say is acceptable, you are wrong.
An output IS also called a terminal.
A mono amp CAN be bridged. Case in point the Dual Mono Amplifier. The picture was provided and it can indeed be bridged. Not only can these things happen they DO happen, have happened for a long time. If you weren't so hard headed and stubborn and unwilling to expand your vocabulary you could avoid these arguments.
“A” mono amp cannot be bridged. It has nothing to be bridged with.
Multichannel amps or even independent mono ampS can be bridged.
You can make up all the vocabulary and definitions you like, but it doesn’t change those facts.
So, what were you trying to prove by showing that diagram?
He spent a whole maybe 5 seconds of a 17 minute video acknowledging that Covid also causes MS. Never discusses the fact that MS after real Covid is significantly higher than with the vax. No mention of how these side effects are inherent to vaccines in general, etc. Like I said 1/2 the facts may work for some people - doesn't cut it with me. (In all fairness, he may have mentioned these facts in other videos, but I'm not combing thru all his videos to find out).
How cute. Thxone frustrated again by not knowing.
Reactionary. Like a spoiled child.
How cute. RobGMN too stupid to know.
Repetition. Like a child.
This is what you do. Ignore proof, evidence, facts even when you demand them then keep asking the same questions over and over as if nobody answered them, keep making the same statements over and over as if only you are correct.
Have you noticed you seem to have a 100% record on this forum? That record being that everyone else is wrong and you are always right. Somehow, no matter what people say, you seem to have an answer that shuts them down.
No I've always been saying you're an idiot because you either had zero clue what was being talked about it that thread (monoblocks)...or you're so f kn full of yourself you can't accept common terminology unless 100%technically correct...so you missed the point once again Rob...I've been pointing out you're idiot this whole time 🤗
Clifff150
Clifff150
Texas
administrator
