what is clipping and how do i avoid it
  • 4
heyhi1
nyc
Reading some stuff on here and someone said they blew speakers due to clipping. From what i read looking it up it sounds confusing but will setting gains properly and setting crossover properly eliminate any chance of clipping?
Can't completely eliminate the chance. If your music source is garbage and full of clipping, that's what you'll get out.
Also, some music purposely has clipping in it.
Clipping in music is fine (coming form a song that's clipped), it won't harm speakers. The problem is clipping from the amp. Some clipping is ok and will happen.
Rule of thumb is if you are listening and it's loud and starts sounding like crap then it's clipping to much and you might start blowing some components of your system up.
When music starts to sound compressed or hollow
strange noises like static, screaches,pops, basically when the song no longer sounds the same so much
Those are usually clipping.
Clipping with mids and highs are easy and apparent to spot out.
When it comes to bass and subwoofers, most of the times you will not hear clipping or have any clue its happening unless you have a heavy clip in which it actually distorts the tone of bass.
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
818
Don't recall off hand. Both single dins. One excelon, one not.
953
1. make sure you wired your subs right... https://jlaudio.zendesk.com/hc/en-us/articles/204374200-Dual-Voice-Coil-DVC-Wiring-Tutorial 2. set...
10
Even a basic TL072 will do this function just fine. LoL. The joys of comparators!
34
6K
I would pull the HU and bench test it. Can be done with a 12v battery on a non-metal work bench easily enough.
16
heyhi1
heyhi1
nyc
Jeffdachef
    May 31, 2024
    May 24, 2024
