What fabric do you use to wrap a fiberglass project
Be carefull though I grabbed some stuff at walmart and stretched it and thought "wow this is really stretchy" later did I find out it only stretched one way. It worked but it was b****. Cant remember what it was. It was on clearance so i never even looked.
Go to the fabric section in walmart and just pick something stretchy that is just thin enough to allow all the curves in your specific work. There is no wrong fabric as long as it absorbs resin and stretches to your needs.
You can also use pantyhose to keep the finished project lighter in weight. The thinner and lighter the material used for stretching the better, because NOTHING just soaked with resin—unless it is specifically designed for it—will have ANY strength for car audio application. You are best to use the absolute thinnest and lightest material and spend your time and money adding layers of fiberglass mat rather than on gallons of resin that will be needed because fleece soaks up a LOT of it (and have no functional strength in the end) and adds a lot of weight. 6 to 8 layers of mat will be no stronger with fleece under it than it would be with panty hose under it.
However, if you choose fleece, fabric stores such as Joanns and Rag Shop carry it.
exactly... preferably someone elses though //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
*two guys walk into a fabric store*
Us: "hey, we're looking for some material"
Store assistant: "what type of material?"
Us: "Ah, stretchy stuff???"
CJL
CJL
oZone
Flipx99
