What do I do?
FeelTheBeat
I have a 1987 GMC Sierra Short box, normal sized cab with a bech seat. There isn't a whole lot of room behind the seat or anywhere else. I was wonderin what i would have to do to fit a couple good sized subwoofers in there along with a couple of 6x9 speakers behind the seat. I'll aslo be needing an amp put in somewhere too. Any suggestions. (i know it'll be difficult)
I have seen some dudes put subs in, the box would run up to the back window edge and and extend to the with of the cab. at the bottom the box would be wider like a wedge shaped boxinside the box make a couple compartments for the 6x9s and slap two 8, or three 6 1/2 ect and mount the amp under the set. build box to specs
i gather you are talking about a ute so the best idea is to make friends with a good engineer and get them to cut the holes for the sub in the back fire wall to mount the subs in and then you couold make a box to put the subs in and wala dunno about 6x9's don't like em but amps under the seat is a good of a place as any
FeelTheBeat
FeelTheBeat
Canada
FeelTheBeat
