What capacitor should i use?
I hope im in the right part here but here goes hope you can help me.
Ive been slowly getting a system for my car together for 6 months. I currently have 2 15' type r's. 2 bxi1208d hifonics amps. headunit and new doors and rears.
Only thing im kinda lost at. How am i supposed to power this? I already planned on running 0 guage to a hybrid cap. But would say a 30 fared cap really work for three amps running my subs and interior? What should i get to power them. Im not exactly on a budget. But i have 500 at the moment just to build the box wires and cap.
It's a 94 Ford Tempo btw so it doesn't exactly have the best alternator.
Just invest in one good deep cycle battery (not two on that alt) capacitors do nothing really except hamper a system that's already starved of voltage all a cap is going to do is give your alt one more thing to have to charge
should be but you are going to eat up that alt in a hurry with the current draw being pulled off it and adding more battery's will not help when the alt is that small it will give you a lower overall voltage level and burn out the alt even faster then the one battery and system, and that would be because you will be pulling more power then the alt can create therefore you will be running on battery power on high levels(anything over your alt's specs) and when the system over rides the alt you get battery's dropping in voltage which the alt will need to recharge once the system is turned down and power can flow back into the battery
Well honestly i looked into getting a HO alt on the car. Apprently Most 94's used the same alt even the trucks if i remember correctly meaning i can get a HO pretty easy for it. So say i look into a high alt and the hc800 id have zero electrical problems? Im pretty dedicated to making my system loud as all hell. So im gonna look further into HO now.
I'm not 100% that you will not run into any problems it really depends on the amp/amp's and how efficient they are if you go with a larger alt then do a couple battery's for sure then you should be about right just make sure the wiring is dead on(gauge size,clean grounds,big 3) just read up and take your time it's when you try to cut corners that you WILL run into problems.
It would help but that's not quite high output but you will notice a difference in dimming lights and large voltage drops also a overdrive pulley would help to
Alright, just looked more. And found 200 amp alt for the 2.3l tempo i have. Im assuming that would be a big increase from a stop 75.
Atm im looking at buying this and replacing the current battery with a hc800 and running 0 gauge to my amps AND the big 3.
I should be good?
vipergtsrvp
vipergtsrvp
Parma, Ohio, United States,
nateberrier
