Weight of 3/4" mdf sheet?
is this true?
The primary drawback to this product is weight. A 3/4" x 4' x 8' sheet can weigh as much as 70 to 90 pounds per sheet. The density of the core is expressed as the weight of a one cubic foot (1'x1'x1') block of the material. Therefore, an MDF sheet using a 48# (pound) core, will weigh 96 pounds. (48"x96"x3/4"= 2 cubic feet)
10 sheets of 3/4" MDF = 960lbs
4 15" MT's = 244lbs
4 MA HK4000D's = dont know the weight on these yet...
14 Turbostart 16v batts = about 560lbs
1764 lbs before amps, 1/0, etc....holy shit
What I don't understand is why people complain about the weight of MDF while they're using multiple sheets of it. It's heavy, that's obvious. Use TruPan if you want to save weight.
pimpedout97x
Tampa, FL
pimpedout97x
