in great condition and this is the cheapest you will find it i only had it for about a month
* Kenwood KAC-9105D Class D 1800 Watts Max
* CEA-Compliant Amplifier
* 500 watts x 1 at 4ohms
* 900 watts x 1 at 2 ohms
* 1200 watts x 1 at 1ohms
* 1800 watts x 1 Max Power Output
* 1 Ohm Stable
* Fully Digital Power Supply
* Built-In High Pass and Low Pass Filters
* You can link multiple KAC-9105D amps together
* Short circuit, DC offset, overload, and thermal protection circuitry
* Tuned Bass EQ (0-18 dB @ 40 HZ)
* Adjustable Phase Control: 0 or 180 degrees)
* Built In Cooling Fan
* MOSFET Power Supply
* Speaker Level Input
* Signal Sensing Auto Turn On
* Frequency response: 10-200 Hz
* All terminals are mounted on one side for easy installation
* Aluminum die cast heat sink
* Input Sensitivity: 0.2 - 5 volts
* Gold-plated RCA level inputs
* Gold-plated screw terminals
* LED Power-On Indicator
* Preamp RCA output
* Signal Sensing Auto Turn-On
* 4 Gauge Power and Ground Inputs
* Dimensions: 13 3/4" x 2 5/16" x 9 3/8"
* 1 Ohm Stable
* Preamp RCA output
