Want To No Best Amp 4 Me
Okay I'll explain.. Your subs can't be wired to a 1ohm final load. You can either find an amp that will go down to .5 ohm, or you need to find a 2ohm amp. As far as enough power @ 2ohms, look at the kicker zx2500.1. They can be had for 450-500 bucks in pretty good condition and will supply more than enough power.
Ok coo idk how big a fan I am of Kicker i no they make good equipment I'm likening the MMATS more I've been looking into a few of them
But u guys thinking 2500watt 2 Ohm amp will be a good match for what I got??
winner...
Autotek mx3000?
The zx amp line from kicker is a very solid line. I'm not big on their subwoofers but those amps would be my first choice if I needed power at 2ohms.
Kicker amps are beast machines.
Kicker subs, I probably would set them up in a field for some target practice.
TahoeRiddinHigh
TahoeRiddinHigh
Michigan city
Dirtrider4eva
