Walling the Jimmy
csu87
Im doing 2 18s in a wall in my 99 gmc jimmy. probably wont get the wall built for another week or so but heres the subs i just finished building.
Going to be
2 18s in 11.6 cuft with removable ports. 40hz for comps, 30hz for daily
Clif Designs 4800.1lx
1/0 welding cable(already installed)
250 amp Iraggi alt(already installed)
2 big 125ah batteries in back
XS Power VCM
4 soundstream carbon fiber 6.5 comps
Cadence TXA3004
for the subs I used 2 bravox edx motors, a dual 2 flatwound aluminum coil, 4 medium stiff spiders, 2 nightshade cones and some carbon fiber dustcaps that James (sub2weeker) made for me.
Cadence TXA3004 to run the soundstream comps
Clif Designs 4800.1lx for the subs
heres some pics i took with my phone. once i find my camera, ill get pics of the finished thing and some videos
just test fitting the subs and box. what a pain to get that thing in there. was just .5" too big for my rear opening so i had to put it in at an angle and take my seats out and flip it upright in there
got the sides on and a first layer of resin inside
got it all carpeted and sealed on the sides. still waiting for the resin to dry
pick of the back. put in 2x4s today to add some bracing to the back. was getting some vibrations even with it double baffled and then a third piece of mdf that i mounted the amp to. gonna need to clean up the wiring alittle and figure out where im gonna mount my 4channel amp
still got to put in the comps and cadence amp but its coming along. should finish up this week or next
finished pic of the wall
and a video. had to use my old crappy camcorder so its not great quality and you cant see the flex real well
[video=youtube;O-nuDq1K9hc]
so got metered today.
149.5 legal
151.8 in the kick
bad day today for me though. i couldnt get my back batteries to charge at the correct voltage and they were barely at 14v. voltage was droping to about 12.5. when i was testing yesterday, batteries were charging at 14.9v and dropping to 13.8v. should hopefully get a little higher score with the correct voltage.
csu87
csu87
C Springs, CO
csu87
