w00d
reason being?
Because if you want a veneered finish that you can stain, it is usually easier to build the enclosure then use some wood veneer and stain that instead. You're doing the same thing when you stain run of the mill ply from lowes. It has a core with a veneer top on it. Fishface is right though, you can use the strips, but it's time consuming and it looks cleaner IMO to just veneer it at the end.
so the veneer isnt already stained?
So you buy the MDF and then the veneer to cover it and with that price, you could have just bought some Baltic Birch and had a lighter enclosure that was easier to build.
Birch has it's place and MDF has it's place. Some people enjoy the end grain on Birch and some people do not. Birch is much easier to work with and is much less messy than MDF. Also, if you're worried about end grain and you're serious about your builds, there are more than a few ways around that and some of them are not very difficult or expensive.
If I'm building anything for a home, I'm going to use birch. If I'm building for a car, I'll use MDF.
k12ug
MASTER MASTER
k12ug
FL
helotaxi
