W T T ZX200.4+ cash for.......
  • Thread starter oxsign
  • Replies 0
  • Views 269
oxsign
No Affiliation
1. Product:
ZX200.4 BNIB
2. Specs:
Power: 35 Watts x 4 @ 4 Ohm 50 Watts x 4 2 @ 2 Ohm 100 Watts x 2 Bridged @ 4 Ohm
MOSFET power supply
LED power and protection indicators
Tuned Bass EQ (0-12 dB bass boost at 40 Hz)
Balanced differential inputs make KICKER ZX Amplifiers compatible with any factory radios
Eliminates unwanted noise in a system
Boost, gain, and crossover frequencies are top-mounted for easy access, and a handy protection indicator featuring a new flashing yellow low-voltage light enhances the end panel
Bridgeable operation
Speaker-level inputs compatible (switchable) through RCA connection
Automatic turn on modes: remote, DC offset, or signal sense
Thermal, voltage, and short circuit protection circuitry
Fixed high-pass filter (80 Hz, 12 dB/octave)
Fixed low-pass filter (80 Hz, 12 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 20-20000 Hz
Dimensions: 10-1/4'Length x 9-5/8'Width x 2-1/8'Height
3. Description/Condition:
BNIB Never taken out or hooked up. Depending on what you have, I can add some cash or a set of FUSION tweeters
(Power Rating: 120Watts (max), 40Wats (RMS)
- Sensitivity: 93dB
- Frequency Response: 3KHz - 20KHz)
4. What you are looking for:
Bigger 4ch amp (350-400x4) or a 2ch (400x2)
5. Pictures of your item for trade:
oxsign
No Affiliation
oxsign
Orlando, FL
oxsign
