Visonik V417sx
jjoseph8907
Just wondering if anyone knows anything about this amp, as I am looking to purchase one. Also, I would be using it to push my 2 MTX 451204s which are single voice coil, 4 ohm subs, 225w RMS. Amp specs:
4 x 100W Rms @ 4Ohm Stereo
4 x 150W Rms @ 2Ohm Stereo
2 x 400W Max @ 4Ohm Bridged
How much would this amp put out to each channel if i bridged it (4 ohm load each channel), as it says 400W to each channel MAX; anyone know what the RMS in this scenario would be?
Thanks in advance
Thanks in advance
Generally the bridged output for a multichannel amp is somewhere around twice what the 2 Ohm stereo output for a single channel.
Ergo: If a 2 channel is rated for 100w X 2 @ 2 Ohm stereo then it will normally do somewhere in the neighborhood of 200w X 1 @ 4 Ohms.
In your case if the RMS output per channel is 150w @ 2 Ohm stereo then it will likely do something like 300w X 2 @ 4 Ohms mono bridged. (assuming those RMS output figures are close to accurate which I have reservations about considering the amp in question)
Wow this is old.
Coincidentally all 3 of the multi-channels have 2x20A's, and the Jensen is CEA-2006 certified so I would bet it's 75x4/200x2 ratings are the best representative of what those amps will do. I don't think any is significantly better or worse than the other 2. All servicable budget amps IMO.
I would probably go with the Jensen or PA over the Visonik, and considering the price difference I'd probably go Jensen.
jjoseph8907
jjoseph8907
St. Petersburg, FL
Jh8909
