Are you refering to when it has be remotly started you cant shift it without being in neutral or it wont start remotely unless in neutral? It could be a neutral saftey switch!! usually only used on manual trans though.anyone ever heard of this alarm messing up ur gear shifting ... my example is..
when my car is running it won't **** from park into anything
i have to put the key in the ignition then move car to N then start it and go from there.... Anyone ever heard of this alarm cause malfunction w/shifting??????????????????
If your worried about theaft why not hook some air horns up to your alarm as well as 6 extra mini piezo through out cabin and trunk, I am getting a second set of air horns to put under the rear of the car, already the alarm will make u pretty much deaf cant wait till the 2nd set come.nah i want it to go off........ esp., since i got an extra siren installed inside the car to discouarge some while alerting a h#ll of a lot more people......
i guess you are talking about on the remote unit... press and hold all 4 buttons on the remote until it beeps. then press the lock button, this switches between vibrate and beeping. this is in the instruction manual.viper.....
how do you go from silent mode to mode where it beeps?
viper - 790xv
