need to apply others??
Martin
NY
i got question here.....when we service a throtle body rite.....we use carbon cleaner to remove the carbon that stick on the throtle body rite.....i wan to ask izzit we need to apply any grease or other stuff on the throtle body after cleaning the carbon??.......or just install back the throtle body??pls give some info...thanks......
if you have any available means of blowing high pressure air thru the throttlebody, that will be one of your best options. once you run the cleaner thru it, it will break all the particals loose, but sometimes it won't necessairly remove the deposits, so they're just floating around in there loose waiting to be ****** into your injectors.
Martin
Martin
NY
LoneRanger
Doxquzme
    Apr 21, 2025
Doxquzme
    Apr 21, 2025
