Viper d1200.1 - how to increase + and - terminals
kizzo
I know there are other amps out there that are like this, but my viper d1200.1 has a little plug that goes into the side of the amp to send current throught the +bat and the -ground terminal. It is designed to accept 8awg wire but i need to use 4awg wire, is there some kind of plug or adapter or something that i can use to connect 4awg directly to the amp?
Yup. Stinger makes 'em.
Use these part numbers to search eBay for 'em: S48ADAPT or S48ADAPTPT:
uh, the 1200.1 accepts 4ga, i used to have one
viper wouldnt make a 1200rms amp only accept 4 ga
oh yea, in the terminal, there is a screw thing you screw in that tightens up on a metal tab, take the screw all the way out and then take the metal tab out, and it can hold more/hold it better that way, i messed with that amp for like 15mins trying to get the power wire to quit coming out, took that out and never had a problem
you must have a janked up one or either trying to fit 0 gauge in, cause mine was a tight fit but it still went in
for free just trim the wire down to fitn in, not that hard, you wont see it since its stuck in the terminal
i have 2 viper 1200,s, one is a refurb and both accept 4awg, it is a tight squeeze on the refurb because it is the plug from the DEI 1100d but it still fits. You should have no problem wiring that amp up with 4awg.
so i dont need to use the metal tab in there? i can just shove the wire in the plastic part and not use the metal cylinder with the screw? or should i take out the screw and just use the cylinder?
kizzo
kizzo
All over
dont_smokerocks
