VIDS of my 300m 2 12" 09 rd alphas ~3500 rms
sounds loud, but not for 3k.
clean up the wiring.
take out the t-shirts and make real trim panels.
take that amp off the read deck. (i wonder how long before we see the "someone stole me amp" thread from you)
fix the passenger rear door.
Only a 144 from 3000+??
You might wanna remove that amp from the rear deck, just asking to be jacked
yea my number is kinda weak and i was going all out to get there meaning i turned the volume way past what i normally have it at (probably not the best idea since my subs have under 6 hours play time, but it was only 10 seconds)
but it sounds amazing inside the bass is clean and the components are loud and clear and keep up well with the subs
fyi to everyone worried about my amp. I have had my past 2 amps on my rear deck. Never got any stolen. I have a car alarm. I have Tint. I have had amps mounted to my rear deck for almost 2 years between the two of them
and No my boxes are not sealed from the trunk theres about a 1 inch gap between the top of the box and the bottom of the rear shelf support beam. the sides are stiffed with shirts for temporary lol.
whats wrong with my passenger rear door?
He was going more for a flat response, low and still loud box design.
If he was going after numbers we would have to use a single box, much larger port and much smaller box.
do you have the dual1s or 2s? i cant remember
dual 2's but they read 2.8.
batts are kept on box because there is a lip on the rear shelf which wedges the batteries on top of the boxes. i am going to screw the trays to the bottom of the rear shelf and the back of the support beam eventually but i need to make my trim panels and everything else but its fine for now that physically cant come off of the boxes unless the boxes are pushed 90% of the way into the cabin of my car.
I dont have anything wrong with any of my doors except the pock on the driver rear door got pushed in i still need to pull it back out but other than that theres no damage
sorry i meant driver's rear door - the giant dent/scratch.Ghetto supastar that is what you are, comin from afar reachin for the stars...
oh you mean the dirty streak. yea i took the vid right before a washed and waxed my car probably should have reversed the order.
2.8? u sure ur meter isnt messed up? i think my hw reads 2.5 cuz my dmm reads like .5 high or, i got a new dmm but it keeps moving from like 1.8-2.4 so i figure its like 2-2.2ohm
ill take some later today after work. what do you wanna see? its completely stock and original except for the side pipes were removed and headers were added.
its my dads but hes giving it to me for my college grad present. it needs a ton of work to get up to my standards but ill find the time some day.
Side, front back and dash. I had a midnight blue '80 with glass t-tops and a 4-speed manual. Just memories I guess.
yea i guess 2.2 then i forgot my meter reads .6 when touched together.
mendon mafia
`94 caprice, 15" Fi BTL
mendon mafia
Cocoa Beach, FL
Alpine4life89
