Velleman Hps10 Personal Scope, 85 shipped
10/10 mechanical
9/10 phsyical only miss the screw that screws down the batter cover, but it still slides on and stay on
specs:
The Velleman PersonalScope is not a graphical multimeter but a complete and portable oscilloscope, with the dimensions and at the cost of a good multimeter. Its high sensitivity - max. 5mV/div - and extended scope functions make this unit ideal for hobby, service, automotive and development purposes. The PersonalScope's favorable price/quality ratio makes it ideal for educational use. You can perform measurements on audio equipment, mains voltage applications, digital signals, all kind of sensors, signal analysis in automotive applications, car stereos, etc... The state-of-the-art RISC processor operating at 20MHz provides the processing power for the ultrafast, fully automatic setup function. Specifications: Maximum sample rate : 10MHz Input amplifier bandwidth : 1MHz (-3dB at 1V/div setting) 1Mohm//20pF (standard probe) Vertical resolution : 8 bit (6 bit on LCD) LCD graphics : 64 x 128 pixels dBm measurements : from -73dB to +40dB (up to 60dB with X10 probe) ± 0.5dB True rms AC measurement : 0.1mV to 80V (400Vrms with X10 probe) 2.5% accuracy Time base : 20s to 2µs / div in 22 steps Input sensitivity range : 5mV to 20V/div in 12 steps (up to 200V/div with X10 probe) Power supply : 9Vdc / min. 500mA adapter Batteries (option) : alkaline type AA or NiCd/NiMH rechargeable (5 pcs required) Battery life : up to 20 hours with alkaline batteries Safety : meets IEC1010-1 600V Cat II, pollution degree 1
Features: * Fully assembled and tested * True RMS or peak to peak read out * Markers for voltage and time * DC readout w/zero reference function * Frequency readout through markers * Screen hold function * Probe setting: x1/x10 * Auto power off * Low battery indication * Contrast adjustment * Auto set up * Adjustable trigger level * Trigger mode: normal, auto, or single * Trigger slope: -/+. The Velleman Personal Scope is not a graphical multimeter but a complete portable oscilloscope at the size and the cost of a good multimeter. Its high sensitivity - down to 5mV/div - and extended scope functions make this unit ideal for hobby, service, automotive and development purposes. Because of its extreme value for money, the Personal Scope is well suited for educational use in schools and colleges. Suitable for measurements on audio equipment, mains voltage applications, digital signals, all kind of sensors, signal analysis in automotive applications, car stereo, etc. The applied state-of-the-art RISC processor operating at 20MHz provides the processing power for it's ultra fast full auto setup function, which makes measuring waveforms very easy. Can be powered by either a 9VDC, 500mA AC adaptor, (not included) or five "AA" Alkaline or ni-cad batteries. Net weight: 1lbs. Dimensions: 8-7/8"H x 4-1/4"W x 1-1/4" D. Mfg.# HPS5
10/10 mechanical
specs:
