USAudio US-2150V tube amp
gckless
San Antonio
Item(s) for Sale: USAudio US-2150V
Item(s) Description/Condition: BNIB. Bought it when I was in Japan. Was verified working in Japan, have not had any way to test it after I moved, however it was well taken care of during the trip. Original tubes. Not much info on these amps, because they are rare. Amp says it will do 150Wx2 at 4 ohms, should do more than that.
Price: $325 shipped
Shipping and Miscellaneous Item Information: On me.
What's the specs on this? Can't read Japanese. Lol
Rated at 150Wx2 @ 4ohms, but judging by the guts, it should do more than that, and sound great doing it. Can't recommend running below 4ohms. Other than that, I don't have THD or anything like that. There's not much info on these amps :/
Too busy at work to notive that you had this listed. Very stout power supply and a tube input section, I see no reason why this wouldn't be heaven on a well-equipped front stage.
Found some specs! They were right on the box -_-.....I'm dumb.
600W maximum output
150W RMS per channel
Built in 3-way crossover (hi/low/flat)
Variable Low Frequency
Bass boost at 40Hz
Pre-amp line out
1.3 ohm stable (Tri mode)
THD: .017
Triple Protection built in
And if you look at the pictures, it is bridgeable. Do not have any specs for that though.
I was at a local shop in Japan where one of these were installed, and the SQ was freaking sweet. The owner had this powering some Diamond HEX components and it was something I've never heard before. Very nice imaging with very nice quality. I will say if you are looking for SQ, then I would highly recommend this one.
CAF, Williston Audio Labs(Old School Car Audio) and Jonathan Patrick's Brand X videos when I'm trying to wire an alt into a newer vehicle I...
16
gckless
gckless
San Antonio
gckless
    May 18, 2024
    May 18, 2024
