I'm selling an Ultimate Digitalis DD1-1300S in excellent condition. Amp was used to power an Adire Audio Brahma 15" sub. I guarantee thing will put out as much if not more power than a JBL BP1200.1 and run cool while doing so. Clean cheap power here and lots of it.
If you are not familiar with Ultimate Sounds they have been around since 1975 and are based out of Canada. They are huge in Europe and South America. You can check out their website here:
http://www.ultimate-sound.com/about.html
Also, here is a review carsound did on one of the 1300S' baby brother amps.
http://www.carsound.com/reviews/amp...te_DT2-800.html
Specs:
Features:
Class D Design
Over 80% Efficiency
Full MOSFET Circuitry
Regulated Power Supply
1-Ohm Stable
Variable 24dB / Octave Low-Pass Crossover
Variable 24dB / Octave Subsonic Filter
Variable 45Hz Bass Boost
0-180° Phase Switch
RCA line-level and speaker-level inputs
Line-level preamp outputs
Thermal, DC offset, short circuit, and fuse 4-Way protection circuitry
Specifications:
RMS Power: 500W x 1 @ 4 Ohms
Bridged RMS Power: 900W x 1 @ 2 Ohms
1300 watts RMS x 1 @ 1 Ohm
THD at 4-Ohm RMS Power:
Preamp Outputs: yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 15-250 Hz
Signal to Noise Ratio: >90 dB
Dimensions: 10.6" W x 2" H x 15.75" D.
$165 shipped O.B.O.
Also selling a Stinger Digital ANL Fused Distribution Block. It's a 2 Position ANL Digital Fuse Holder HPM with a Digital Voltmeter Display that accepts 0 or 4ga inputs and outputs. Will throw in 2 ANL 100 amp fuses with it as well.
$30 shipped O.B.O
email me for pics or any questions: global_groove6@yahoo.com
Specs:
Features:
Class D Design
Over 80% Efficiency
1-Ohm Stable
0-180° Phase Switch
Specifications:
Preamp Outputs: yes
$165 shipped O.B.O.
$30 shipped O.B.O
