True or false?
he is essentially right. the shorter the cable, the more current it can flow safely. also when he says amps he means amperes and not amplifiers...just fyi. there is a chart somewhere that shows what gauge wire you need depending on length and current draw....
The more resistance there is, the more heat that will be generated. A longer piece of wire has more surface area to create this friction than a shorter piece, therefore it will generate more heat, which will yield less power handling (current flow).
This is one of the reasons why its usually acceptable to run a 2 or 0awg wire back to a distribution block in your trunk (for example), and then branch off to the amps with short runs of 4 or 8awg. Those shorter runs of smaller gauge wire will/should handle as much current as the longer run of the larger gauge wire.
MetalMaxima
AURAL DESTROYER
MetalMaxima
The Garden State
zachzchw
