Sold Treo ssx 12 Cheapp!
trunks9_us
Ok here the deal Its a treo ssx12.22 but one of the tinsels is broken on one of the sides. The sub still works but its now running 2 ohms only. So this sub will still handle the brutal power of 2500rms but needs to be a 2 ohm amp now. I am asking 180 shipped.
correct me if im wrong but this wont work correctly unless you have the tinsel replaced, because if you only use one terminal only one coil will be working..right?
Thats the same thing I asked But I was told that the sub will still use its full power and thats the reason its dvc is for the ohm load differences. It does make perfect sense since the sub still pounds hard.
idk how to work on subs I just know how use them. I suppose if someone who knows how could buy this then fix it themselves. but then it makes them go back down to 1 ohm or 4 ohm load.
well my friend over here works on woofers and recones,fixes tinsels...for cheap....but yea thoug like you said who ever buys it could fix that...if i had the money ill take that woofer from you...im been looking for a 2000+ watt sub for a while now
Anyone with 5 minutes of time and a soldering gun can fix it...I've repaired tensils before on subs that way and it works just fine. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
trunks9_us
trunks9_us
college station tx
rumblebee2
