trade my xtant 2200i for mb quart seperates
pickup1
got a good condition xtant that i need to trade for some seperates.6 1/2" prefer.
let me know here or email...pickup1@prodigy.net
i'll get some pics in a little bit.
this is a 100 x 2 with a built in noise gate.
This is an old and fairly rare 2-channel Xtant amplifier. It was the largest 2-ch amplifier at the time, and is perfect for a high-end component set, or a fairly large sub. This is the stuff that made Xtant famous, the sound quality is amazing. Here are the features, but please don't hesitate to ask me any questions. The amplifier is in perfect working order, guaranteed to work when you get it or your money back. Thanks for looking, and check out my other auctions!
FEATURES
Bonded Fin Cooling: Aerospace technology with forced convection cooling for enhanced thermal performance.
Transitional Supply: Fully regulated, high efficiency power supply provides lower current draw at rated output power.
Crossover: 18 dB per octave Butterworth filter network with selectable Bypass (Full Range), High Pass, Band Pass, or Low Pass modes of operation. Frequency Selection is via a 12 pin Frequency Module (SIP). The amplifier is shipped with a 90 Hz SIP installed, 13 other frequencies are available from your Xtant Dealer. Refer to page 7 of this manual for a list of the available frequencies.
Noise Gate: Provides deep muting when no musical signal is present. Features include adjustable threshold and bypass switch.
Balanced / Floating Input: All ix Series amplifiers are supplied with Balanced / Floating inputs. This circuitry helps to eliminate system noise associated with ground-loops.
Modular Expansion Port: Xtant amplifiers are supplied with a modular port used for docking any of Xtant's signal processing modules.
Protection Circuitry: Both Thermal and Overcurrent protection has been incorporated into all Xtant amplifiers. In the event of a problem, the amplifier will reduce its power to maintain operation.
Status LEDs: Four LEDs, visible through the cover, indicate operational status of all Xtant amplifiers. The red LED illuminates when the amplifier is ON, the green LED indicates when the noise gate is open, the yellow LED indicates that overcurrent protection is employed and the orange LED indicates that the thermal protection circuit is operational.
SPECIFICATIONS:
Frequency Response: 5 Hz to 50 kHz +/- 1 dB
Number of Channels: 2
Watts per Channel @ 4 Ohm: 2 x 100
Watts per Channel @ 2 Ohm: 2 x 200
Bridged Mono @ 4 Ohm: 1 x 400
Recommended Load: 2 ohm Stereo / > 4 ohm Bridged
Distortion (THD)
Signal to Noise Ratio: > 100 dB
Damping Factor: > 200 @ 100 Hz with 4 Ohm load
Input Sensitivity 100 mV to 8.5 V RMS Unbalanced Source
100 mV to 17 V RMS Balanced Source
Input to Line Output Gain: 0 dB +/- 20 dB, Selectable in 10 dB steps
On-Board Crossover: 18 dB per Octave Butterworth
Module Port: 1 - Accessory Port
Power Supply: Fully Regulated, Transitional
Operational Voltage: 11 to 15 Volts
Fusing: 50 Amp
pickup1
pickup1
Polk City Fl
pickup1
