Tons of install accesories all Rockford Fosgate - Perfect Interface
Goindef154
Nothing
5,477
Phoenix, AZ
--4 pack of female connectors 12 or 16 gauge in black - $.25 each pack
--4 pack of 12 or 16 gauge fork terminals in black - $.40 each pack
--90 degree 4 pack of 12 or 16 gauge fork terminals in black - $.40 each pack
--4 pack of 8 gauge fork terminals 2 red/2 black in each - $.75 each pack
--4 pack of 4 gauge Couplers in red or black- $.50 each pack
--4 pack of 8 gauge couplers in black - .50 each pack
--4 pack of Monster 30 amp AGU fuses - $2.00 each pack
--Three 4 gauge in to four 8 gauge out AGU Fuse block - $8.00 each
--90 degree RCA plug adapters - $1.25 each
Some of the packages are dirty but everything is brand new
They all have rubber inserts that go over them, not the cheap plastic ones.
Prices are above^^^^
Everything is plus shipping but since they're light shipping is usually cheaper, like around $2-3 usually.
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Those subs are 400w RMS each, and that dual enclosure is 800w RMS with a 2ohm load. That's a 4ch amp that does 55w x 4 @ 4ohm, & 75w x 4 @ 2ohm...
754
Thank you for your kind replies. I have decided to use an amplifier I purchased for another install, but subsequently never used. I was...
951
Goindef154
Nothing
Goindef154
Phoenix, AZ
Gordon 24
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
