Tire PSI
the # on the tire is the MAX the tire can take. usually you will want to go with the recomended psi from the car manufacture. iam a tech at a local lexus dealer and when we get a car with aftermarket rims, we will usually go with 5psi less than the max on the tire.
dose your car/rims have the tpw sensors?
ya that would be a bit much, try 40. that should be good. keep in mind that the 55psi is the max so if you were to put 55 in it now(cold)when you go out and drive the psi will increase as the tire heats up and you could have a tire failure so go with a lower amount so you will have some leeway. 40 should be just fine.
-vic
You ALWAYS go with the rec psi for the VEHICLE.....as stated before the number on the tire is the MAX pressure for the tire....most vehicle will be between 32-35 psi...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:D:D
on my car i go with 35. my wheel/tire combo is a little different though... lol
Should i keep it there?
Look at the label on the inside of the drivers side door jab and it will tell you want your vehicle requires and go by that for optimal performance......//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:D:D
i have 22" rims with low profile tires, they arent factory
It don't matter, you always inflate to the vehicle's spec....I do this on a daily basis, it don't matter if they are 15" factory tires or 30" aftermarket's..//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:D:D
jshak07
148.4 and climbing
jshak07
louisville
DARKHART
