wow
Audiophile Features
Die Cast Zinc Faceplate
Heavy Machined Volume Knob
Vacuum Fluorescent Display (VFD) with Independent Power Supply
Copper-Plated Chassis
3-Layer Nickel Finish CD Mechanism
Glass Epoxy 4-Layer PC Board
Burr-Brown Volume Circuit with 0.5 dB Resolution
Zero Cross Detection Muting
24-Bit Burr-Brown D/A Converter
96 kHz Sampling Frequency Upconversion
4 DAC Differential Configuration
8x FIR Oversampling Digital Filter
Analog Devices High-Speed Operational Amps
48 kHz Frequency Response
96 kHz AKM Digital Signal Processor (DSP)
Digital Time Alignment with 0.7cm Steps
0-500cm Adjustment for Each Channel
4-Way Digital Crossover
Variable Crossover Frequency, Slope, & Phase
Fully Parametric 5-Band Equalizer
8-Channel 4-Volt Preamp Outputs
Silver-Plated Conductors
6N Oxygen Free Copper (OFC)
Gold-Plated, Metal Barrel RCA Connectors
Outboard DC/DC Converter Power Supply
Black Finish Copper Chassis
Die Cast Aluminum Casing
Custom Silmic II Filter Capacitors
Toroidal Choke Coils
Gold-Plated Power Terminals
CD-R & CD-RW Playback
Magi-Tune AM/FM Tuner with 24 Station Presets
CeNET Control for CD Changer, TV Tuner, or Sirius Satellite Tuner (satellite tuner requires Clarion DSC920S)
Dual Rear Analog Auxiliary Inputs
Optical (S/PDIF) Digital Input & Output
Preamp Only (requires outboard amplifiers)
Included Wireless Remote Control
Step-Up Features From the Clarion DXZ945MP (and pretty much any other head unit)
Burr-Brown D/A Converters
0.7cm Step Digital Time Alignment
5-Band Parametric Equalizer
0.5 dB Burr-Brown Volume Circuit
Optical Digital Input & Output
