THE Thread
what xover settings does it have? what slopes? is it a 3-way xover?
Yes, both are 3-way capable
slopes-6db,12db,18db, 24db
settings-Im not real sure on the setting in 3-way mode, because currently im in just regular Front/Rear/Sub mode, but it allows me to cross my sub at anywhere from around 60Hz, to 100Hz, and my fronts can be crossed anywhere from 80 up to 200, But im sure the settings are much wider in 3-way mode.
Both are nice units, the glide touch isnt as bad as people say it is, and for somebody like you coming from an eclipse deck, it wont be a hard change (most complaints were fom former alpine owners, and they liked using the rotary encoder to scroll through menus better). The bio-lite on the 9855 is great, and not to mention it has digital time alignment, a 5 band parametric Eq, or a 7 band Graphic. I liked both of them, I upgraded to the 9855 because of the increased preout voltage and the display
Ng summed it up...and I forgot about the attenuation, you can adjust levels all the way down to -12db.
Yes, both are 3-way capableslopes-6db,12db,18db, 24db
Both are nice units, the glide touch isnt as bad as people say it is, and for somebody like you coming from an eclipse deck, it wont be a hard change (most complaints were fom former alpine owners, and they liked using the rotary encoder to scroll through menus better). The bio-lite on the 9855 is great, and not to mention it has digital time alignment, a 5 band parametric Eq, or a 7 band Graphic. I liked both of them, I upgraded to the 9855 because of the increased preout voltage and the display.
so the only difference between the 53 and 55 is the display and preout voltage?
The BioLite is WELL WELL WELL worth it. Amazing.
I couldn't even imagine the shittiness of trying to use glide-touch with a dot-matrix display.
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
nG
RangerMan
Premium Member
Premium Member
RangerMan
NC
x2o
