*Do do not delete a post unless it is abusive to other members, contains spam, or is obscene (contains obscene language, ******, racial comments, hate messages, etc). If you are unsure what do do, please report it to us and we will take care of it. Please use utmost care in deleting posts!
*When deleting a post in The Lounge, or closing a thread, please use EXTREME caution. The Lounge was created to give users a mostly unmoderated forum to discuss whatever was on their mind. At first, we were against any sort of member moderation, simply because it wasn't out of control. However, as the forum has grown, so have the number of obscene posts. Because of this, we have decided to allow moderators to step in to help control it. However, you must be very careful in what you moderate! Please do not delete a post that does not contain ******, threats, or very obscene messages. You should allow 99% of posts to remain unchanged. We will monitor The Lounge to make sure what is deleted, needs to be deleted. Also, do not close a thread unless it is absolutely necessary!
*Please make SURE you enter a reason when deleting a post/thead.
*Only close threads that cleary need to be ended due to obscene, or hassing posts. Use this wisely, as we have found it angers alot of members when a thread they started is closed. Please use this option before, or if you can avoid deleting a thread. Remember, deleting a thread is the last resort and should only be used when the CarAudio.com TOS have clearly been violated.
