HOOOOOOOOOOOOOLY SHIT!!
I just saw pics of this guys install...White Escalade Truck with lambo doors, the new XX Hifonics Maxximus, 3 15" subs (dunno what). And in the back right behind this 10,000 watt Beast!! was a 42" Plasma..... here are the stats in case some of you have never seen/heard it. I will get pics as soon as I see it in person.
The new HiFonics Generation XX digital amplifiers mark a new era for the company that pioneered many firsts in mobile amplifier technology. These brutal amplifiers run extremely cool, even when driving difficult 2-ohm loads. HiFonics' Ultra D-Class technology allows these amps to put out incredible power - like 10 kilowatts! The Maxximus features double-sided glass epoxy PC boards with extra large traces for maximum power and signal transfer. Other features include a fully variable 24 dB/octave low-pass crossover, fully variable 24 dB/octave subsonic filter, line outputs, remote bass level controller, balanced DIN input (compatible with optional XI-BLD or XI-BLD1P line driver), and quad 2/0 gauge molded power connections. The Maxximus is capable of a continuous 10,000 watts of clean output into a 2-ohm mono load. Now that's "Power From The Gods"! Requires external fusing and high-output alternator. Recommended fuse size is 1,000 amps.
This item ships via ground freight service only. Typical delivery time is 2-3 weeks.
Features
Ultra D-Class Digital Operation
Dual Mono Configuration
Full MOSFET PWM Circuitry
Quad Turbo Power Supply Torroid Transformers
Ultra-Fi MOSFET Output Transistors
Remote Bass Level Control with Diagnostic LED
2-Ohm Optimized: 10 Killowatts x 1 at 2 Ohms Mono!
Fully Adjustable (35-250 Hz) Low-Pass Crossover
Fully Adjustable (10-50 Hz) Subsonic Filter
Balanced DIN and Unbalanced RCA Inputs
Variable 0-18 dB Bass EQ @ 45 Hz
Variable 0-180° Phase Control
Full-Range RCA Line Outputs
Quadruple 2/0 (Two Aught) Gauge Molded Power Connectors
Huge Vented Heatsink
Illuminated "HiFonics" & "Maxximus" Logos
Removable End Caps Cover Wiring
Comprehensive On-Board Diagnostics
Optional XI-BLD or XX-BLD Balanced Line Drivers
Requires External Fuse (available separately)
Power Output
4 Ohms: 2 x 2,000 watts RMS / 1 x 7,000 watts RMS bridged mono
2 Ohms: 2 x 3,500 watts RMS / 1 x 10,000 watts RMS bridged mono
1 Ohm: 2 x 5,000 watts RMS
