The most convenient way to convert MOD file to Adobe Premiere for editing
As we know, Adobe Premiere Pro is a real-time, timeline based video editing software application. An entry-level version, Adobe Premiere Elements, is available for the consumer market on Windows. Some of the notable advantages of Premiere Pro over Premiere Elements are multiple sequence support, high bit-depth rendering, multi-camera editing, time remapping, scopes, color correction tool and advanced audio mixer interface. With either of them, people can edit any videos such as HD, SD and DV in real time. But, presently, I’ve often met such a question asked by many users online like “I have JVC Everio GZ-MG57 which produces MOD files that I'd like to import them to Adobe Premiere for editing, but it is impossible.” What’s up? It turned out to be that .MOD is a special video format which can not directly read by most editing software or media players. Owing to obsolete version of Premiere those people used or incorrect OS, they can not import .MOD to Premiere any longer. To help these people out, I’ve tried every means to look for a really effective way. Accordingly, hereby I can wait to share this good news with you. This article focuses on solving this problem.
The most convenient way I found is to use Moyea MOD Converter. As Premiere Pro is compatible with MPEG and AVI, this converter will definitely help convert MOD to MPEG, MPG and AVI. The below easy step-by-step guide will show you how to convert MOD to Adobe Premiere.
Step One: Freely download and run this program, then the following picture will pop up.
Moyea MOD Converter designed for the digital camcorder lovers to edit and convert MOD files derived from Panasonic SDR-H20, SDR-S26, Canon FS100, FS200, or JVC Everio GZ-MG57, GZ-MG100U, etc. After the conversion, people can make the recorded MOD files playback on their cherished portable players like iPod, iPhone, PSP, or editing software such as Adobe Premiere, Windows Movie Maker, Sony Vegas, etc.
Step Two: Load your MOD files exported from you HD Camcorder by hitting "Add" icon or dragging them directly to this program, specify the output video/audio format like Xvid (*.avi) using drop-down list of “Format”,then the pop-up picture will shown as below:
Step Three: if you want to combine batches of MTS files into single file for conversion, you can tick the check box "Merge into one file". Or you can directly define your own destination folder by “Open” button or by default.
Step Four: Video/audio parameters settings
For more satisfactory video and audio, you may click "Settings" to adjust the video/audio resolution, including Codec, Sample Rate, Frame Rate, Size and Channel.
Step Five: Hit "Convert" icon to start the conversion.
After the conversion, you can freely drag the converted MOD files to Adobe Promiere for editing.
Tips:
Moyea MOD Converter features built-in multi-thread encoding technology, which speeds up the conversion speed than ever. It is estimated that you can save at least half time to convert a MOD video with similar software.
This program utilizes unique audio and video sync tech, which can completely eliminate the audio and video stutter or out of sync issues and further guarantee the output video and audio quality.
Its built-in codec won’t install any codec on your computer in order to avoid unexpected codec problem.
Most importantly, it boasts “Deinterlacing” function. By choosing the check box “Deinterlacing”, you can convert interlaced video into a non-interlaced form, so as to enjoy a better and clearer video effect.
Tips:
