Sold tc-3000 and 40.1 for sale if the price is right
blockrocker13
i have two tc-3000 qvc for sale im asking 1000 for them both plus shipping
i also have a 40.1 for sale asking 800 obo it is 100% in working condition and about a 7 in apperance i want to sale them togther local pick up is prefered tx me at 832-814-4455 for pics trades will be amused
the motors in the subs handle 3000 watts rms i got the pics coming up and they were built from tc sounds because they are no longer doing buisness with audiopulse if u want call thilo stopler from tc sounds your self
look man the motors that the subs have are not rated no 1500 rms the motors in the subs that were built from thilo stompler from tc sounds said they do 3000 watts rms now if you just want to bull shit all day with me i aint got the time
motors alone do not have power ratings
12″ 15″
Qts 0.33 0.40
Re (series) 4.7 Ω 4.7 Ω
Fs 25 Hz 22 Hz
Cms 125 µM/N 135 µM/N
Vas 44 lit 126 lit
Mms 310 g 390 g
BL (series) 26.2 Tm 26.2 Tm
Sd 0.050 m² 0.082 m²
SPL 85.2 dB 87.4 dB
Specifications 12″ 15″
Voice Coil Configuration D2 | Q1 Ω D2 | Q1 Ω
Mounting Depth 7.99″ 9.48″
Driver Cutout Diameter 11.16″ 14.02″
Overall Driver Diameter 12.60″ 15.51″
Magnet Weight 225 oz 225 oz
Driver Weight 44 lbs 46 lbs
MSRP $749 $849
Performance 12″ 15″
BL²/Re 140 N²/W 140 N²/W
Xmax 30 mm 30 mm
TLS:
Recommended Amplification 2500 W RMS 2500 W RMS
4th order
reflex enclosure volume 1.2 - 2.1 ft³ 3.0 - 4.2 ft³
2nd order sealed enclosure volume 0.6 - 1.4 ft³ 2.0 - 3.8 ft³
what the aluminum cone does to or wat?
what they are saying is it takes more than just the motor to determine what a sub will handle. for instance, if the surround and spiders can't handle 2kwrms then the sub as a whole can't no matter what kinda thermal handling the motor is supposed to endure
You are clearly uneducated about the subject. You're trying to make the subs seem better than they are by inflating their RMS ratings...I had a 15" TC-3000 with quad 1ohm coils, it was rated at 1500 watts. I also got it straight from TC for $400 shipped.
Now if your subs are something other than a normal TC-3000, then let us know. But as it stands, a normal TC-3000 is not rated at 3kw RMS, period.
blockrocker13
blockrocker13
houston,tx
blockrocker13
