Tactical Firearm Laser and Light: LASERMAX UNI-MAX Green Laser and XTI Procyon Light
EriCCirE
MN
F33LMYWRATH is my ebay name. 100% positive rating with 45 feebacks
Lasermax Uni-Max Green Rail Moun Laser Sight LMS-UNIG $290
Model Number: LMS-UNIG
Package Contents:
Lasermax UnixMax Laser , Laser Housing , Clamping Screw , Battery Cover , Pan Head Screw , Batteries , Adjustment tool , Activation Switch
Description / Specifications:
Unique pulsing beam for high visability.
Integral Picatinny rail system to accommodate a wide variety of accessories
Ambidextrous activation to accommodate the left or right-handed shooter
Quickly and securely attaches to any Picatinny or Weaver Style Rail
Allows multi-use between handgun and long gun platforms
Constructed from FRN (Fiber Reinforced Nylon) for lasting durability
Maintains alignment after every battery change
Light weight (the same weight as one .40 S&W round)
Extra alignment tool (provided) stores inside battery compartment for use on the range or in the field
Specifications:
For: Picatinny; Mil-Spec; Weaver Style Rails w/minimum rail length of 1.75"
Wavelength: 532nm
Power Output: 5mW
Accuracy: User-adjusted for windage & elevation
Spot Size: 5/16" @ 7 Yds; 3/4" @ 25 Yds
Operating Temperature: 10°F - 130°F
Battery Type: Two 1/3N Lithium
I still have the green jewel sticker, only removed to match my setup.
Insight XTI Procyon LED Weapon Light $100
The XTI Procyon LED Weapon Light gives you the ability to Dominate the Darkness with its 125 lumens of stunning white light. Its patented Slide-Lock design and adjustable rail interface easily mounts to most railed pistols while its compact, machined aluminum housing fits existing M3 holsters. The XTI's ambidextrous rocker switch offers the choice of momentary on, constant on or strobing modes necessary to handle any low-light tactical scenario.
Comes with two brand new extra sets of batteries!
Specifications:
LED Output: 125 lumens
Run Time: 90 minutes
Interface: Adjustable slide-lock
Weight: 4.0 oz. w/Batteries
Dimensions: 3.2" x 1.6" x 1.5"
Waterproof: 1 meter/3 feet
Battery Power: 6 volts from two (123)
Package Contents: 2 Duracell batteries and M1913 picatinny latch bar. Universal latch bar installed.
Limited Lifetime Warranty
Mounted:
EriCCirE
EriCCirE
MN
EriCCirE
