T3 Audio T.200 Series Subwoofer - Sub, Speaker, Woofer, 10 inch, 12 inch, 400 watt, competition
Affordable Performance
The T.200 series subwoofers combine powerful bass and musical enjoyment at a very affordable price. Key features include high quality UV treated foam surrounds attached to non-pressed paper cones, stylish silk screened poly dust caps, 4 layer copper voice coils rated at 400 watts peak power handling, powder coated steel baskets, braided tinsel lead wires and a substantial FEA optimized 60 oz. motor assembly. Watching your budget will be no problem with our T.200 series as you're sure to get more performance for your hard earned dollars with features normally seen on much more expensive subwoofers.
Design
8”, 10” and 12” Subwoofers
Black anodized 60oz. motor structure
Durable pressed steel basket
Conex spider suspension
Heavy gauge tinsel leads
Treated foam surround
1 Piece poly front cap with logos
Single 4ohm voicecoil on 1.75” aluminum former
Copper round wire coil 20mm height
200w RMS/ 400w Peak
Parameters
T.200-8s T200-10s T-200-12s
Fs (Hz) 35 34 32
Qes 0.58 0.88 0.74
Qms 8.52 10.43 8.54
Qts 0.55 0.81 0.66
Vas (ft3) 0.64 0.84 1.76
Spl @ 1watt (dB) 85.45 86.45 87.58
X-max (Inches) 0.50 0.50 0.50
X-mechanical (inches) 1.00 1.00 1.00
Re (Ohms) 3.59 3.55 3.89
Pe (RMS Watts) 200 200 200
Piston Diam. (inches) 6.70 8.00 10
Sd ( in2) 36 50 78
BL 10 10 10
Le (mH) 1.72 1.72 1.81
Mms (grams) 65 95 128
Rms 1.93 2.32 2.42
Cms 240.4 161.59 138.35
Zmax (Ohms) 55.54 45.58 44.55
Specifications
T.200-8s T.200-10s T.200-12s
Total Weight (lbs) 6.5 7 8
Motor Weight (oz) 60 60 60
Mounting Depth 3.75" 4.60" 5.00"
Basket Depth 2.15" 3.00" 3.40"
Magnet Depth 1.60" 1.60" 1.60"
Cutout Diameter 7.10" 9.25" 11.20"
Overall Diameter 8.25" 10.30" 12.30"
Magnet Diameter 4.85" 4.85" 4.85"
Spider Diameter 5.50" 6.90" 7.50"
Coil Diameter 1.75" 1.75" 1.75"
Displacement (ft3) 0.03 0.05 0.07
Enclosures
Sealed (ft3) 0.5 0.8 1
Vented (ft3) 0.75 1.1 1.5
Vent Diameter 3"/ 8in2 3"/ 8in2 3"/ 8in2
Vent Length 11" 13" 9"
Note: The enclosures recommended above are optimal size to suit the woofers for best overall performance. Enclosure sizes can vary depending on application. Using enclosure design software with the parameters provided with woofers is a good way to dial in woofers for users specific needs. ALL display room enclosures should be built 50% larger than optimal box recommendation for best open room performance.
