ALL ITEMS ARE OBO & W/O SHIPPING! PM/EMAIL OFFERS PLEASE.
Pioneer Premier DEH-P8MP ...$200
Condition: Headunit in prefect working condition, light scratches on the face from normal wear & tear (not noticeable when the screen is lit). Has remote. See below for specs.
Eclipse 4 channel EA3422 ...$85
Condition: Amp in perfect working condition, light scratches from normal wear & tear, Eclipse sticker has yellowed a bit from age. Will clean fully before shipping! See below for specs.
Memphis mono 1000d ...$250
Condition: Amp in perfect working condition, light nick under the M logo, small cosmetic damage on the lower left hand corner (none of it hurting performance – was like this when I purchased it, works flawlessly). Will clean fully before shipping!! See below for specs.
Rockford Fosgate Power T1 10” Dual 2 Ohm Subwoofer T110D2 ...$150
Condition: Darn near perfect! Perfect working order. See below for specs.
Kenwood eXcelon 6x9 3-way Coaxials KFC-X698 ...$50
Condition: Perfect working condition. Scuff on 1 speaker (person redoing upholstery rubbed something against it, still plays fine – see picture). No grills. See below for specs.
1.5 Farrad Digital Cap Pyramid ...$30
Condition: Perfect working condition. A bit faded from being in the sunlight. Red LED display.
Pictures can be seen here...
Specifications…
DEH-P8MP
CD/CD-R[RW]/MP3/WMA Playback
Detachable, Motorized Face
Max 60x4
RMS 27x4
Intro Scan, Random Play, One Track Repeat
Parametric EQ
Digital Clock
Remote Control
1 DIN Mounting
Faceplate Carrying Case
OLED Display
Screen saver, Telephone Mute, CD-Text Capable, Satellite Radio Tuner Control, Rotary Encoder Multi-Control, TV Tuner Control, IDE3 Tag Support.
RCA 3x Connectors
EA3422
4 Channel Bridgeable
RMS 4 Ohms 50x4
RMS 2 Ohms 70x4
Frequency Response: 20 Hz – 20000 Hz
Signal to Noise Ratio 105 dB
Bass Boost 45 Hz
High Pass Frequency 50 Hz – 200 Hz
Input Voltage 13.8v
MOSFET Circuitry
HxWxD = 5cm x 27.5 cm x 27.5 cm
1000d
1100W RMS Class-D Monoblock Subwoofer Amplifier
Fully Variable Low-Pass Filter: 50 - 250 Hz, 18 dB/Oct
Variable Subsonic Filter: 20 - 50 Hz
Bass Boost: 0 - 18 dB
Gold-Plated RCA Connectors
4 Gauge Power Wire Capability
Power and Protection LEDs
Thermal, Short Circuit, and Overload Protection
RCA Outputs: 1 Pair
Adjustable Input Level Control: 400 mV - 4V
Damping Factor: 300
Dimensions: 13.4" L x 6.25" W x 1.7" H
Number of Channels - Mono
RMS Power (4 ohms)- 300 watts x 1 channel
RMS Power (2 ohms)- 600 watts x 1 channel
RMS Power (1 ohm)- 1100 watts x 1 channel
Bridged RMS Power- Not Bridgeable
Minimum Impedance Unbridged- 1 ohm
Minimum Impedance Bridged- Not Bridgeable
THD at Rated RMS Power- 0.75%
Speaker Level Inputs- No
Preamp Outputs Yes - 1 pair
Built-in Crossover- LPF(50 - 250 Hz), Subsonic(20 - 50 Hz)
High-Pass Crossover Frequency- N/A
Low-Pass Crossover Frequency- N/A
Subsonic Filter- N/A
Signal-to-Noise Ratio- 95 dB
Channel Separation- N/A
Bass Boost- 0 - 18 dB
Bass/Gain Remote- N/A
Fan Cooled- N/A
Fuse Rating- 40 A x 2
T110D2
Rec. Sealed Box Dims: 0.75 - 0.75 cu. ft.
Rec. Ported Box Dims: 1.50 - 1.50 cu. ft.
Free Air Usage: not recommended
Sensitivity: 82 dB
Recommended RMS Power: 600W
Peak Power Handling: 1200W
Impedance: dual 2 ohms
KFC-X698
PBO advanced fiber woofer with rubber surround
2-2/4” PEI cone midrange
1” PEI film balanced dome tweeter
Frequency Response 25-33000 Hz
RMS 2 – 75 watts
Max 300 watts
Sensitivity 96 dB
Top Mounted Depth 3-5/16”
I have feedback on CA.com as coolcalico.
I also have feedback on thirdgen.org as *F-BodyFanatic* and on SoundDomain.com (forums) as *F-Body Fanatic* (I am a moderator there, so online integrity is very important to me).
Please note, I do NOT have any of the boxes for these items. I can accept paypal and money orders. If you want to pay money order, please send me a few references for security purposes. I ship within 24 hours (aside from the weekend of course) and ship everything UPS. I do not do USPS as I’ve had bad luck with them in the past. I can also do FedEx or DHL if you have a preference. On any items above $100 insurance is REQUIRED.
PM me here or email coolcalico2001@yahoo.com with questions or offers.
Specifications…
DEH-P8MP
Max 60x4
RMS 27x4
Parametric EQ
Digital Clock
Remote Control
1 DIN Mounting
OLED Display
RCA 3x Connectors
EA3422
RMS 4 Ohms 50x4
RMS 2 Ohms 70x4
Bass Boost 45 Hz
Input Voltage 13.8v
MOSFET Circuitry
1000d
RCA Outputs: 1 Pair
Damping Factor: 300
Fan Cooled- N/A
T110D2
Sensitivity: 82 dB
KFC-X698
RMS 2 – 75 watts
Max 300 watts
Sensitivity 96 dB
