Thanks for the info. Yeah I'm looking for 6500+ at 2 ohm I'm thinking bout getting a third hcca and running them at 2.67 ohm. That's why the Stetsom caught my eye. I think I'll have to look elsewhere doesn't sound like a durable daily amp at all lolfor burps yes. for daily.... nah. there mostly used for spl and multiple low ohm burps. they are very strong amps if set up right. have to have killer electrical and have ZERO vibration. there magic smoke machines. dont see too many around that use them for more then spl car setups. and for the price i would look into a rd d9, dc 5k, ia40.1, something along those lines for reliable daily amps for $1k
I figured it would do rated but was unsure considering the single inputs. So your saying they are reliable to use daily? Good to use for music? How easy is it to put the dual inputs on the amp?stetsom amps DO RATED PERIOD doesn't matter if u running it daily or not. like does that even make sense? current draw is current draw either it can or it can't pull enough to meet its ratings.
OP you addressed the inputs. They aren't even oversized car audio style 1/0 ga. inputs!!! you have to buy dual inputs to properly provide enough current to the amp (which stetsom sells as well as toolmaker and project db).
Stetsom amps are extremely powerful in a tiny package, as long as you give it enough juice it'll pump out gobs of power daily or however you plan to use it.
Many that NEVER EVEN USE STETSOM regurgitate what others say about the brand. I have used their products and love them. Buying another 7 kd as we speak
yes they are reliable daily. i had a 4k2d 2ohm version running on my nightshade 15 at 1ohm and didn't even get hot. dual inputs vary and mine had to be taped to keep from touching and sparking/shorting out the amp. but that wasn't a big deal. Some dual inputs wouldn't even require that. And they play music flawlessly, matter of fact i would say it sounds better than some other amps ive used.I figured it would do rated but was unsure considering the single inputs. So your saying they are reliable to use daily? Good to use for music? How easy is it to put the dual inputs on the amp?
