Jeff Stetsom
Sales Rep Member
Hello there,
This is our new model on the Vulcan line
It the 1k5 is just 2.56" H x 11" W x 6.69" L
Two Models
the 1k5 h.2 that works with the minimum impedance of 2ohms
the 1k5 h.1 that works with the minimum impedance of 1ohm
95% efficiency means that 95% of the energy that went into the device, the battery wires, were transformed into audio. Lost only 5% into heat.
Usually our amps are 90% of efficiency
ITS STRAPPABLE
the half brigde system is a way to have the circuit transistors output. The advantage of the Half Bridge is that you can add to power them like batteries in series, if you connect the wire to a speaker and amplifier in one other thread of the same speaker, the other amplifier. In the current amplifiers, you have to connect them in parallel and use the link cable to sync.(like in our linked amps)
You can strapped it !!! like this !!
And this is the advantage of this amp you can wiring it like batteries in series like this and you dont need the link cable to sync them !!
Thats why we called it half brigde channel
Two Models
ITS STRAPPABLE
