stetsom 7kd and 7k2d
They are two totally different amplifiers with two totally different designs. The 7k2d is a much better design.
yeah and im debating becasue i can get a 7kd right now but havent had much luck finding a 7k2d //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
basically its probably like a 2.0. Just a better version, maybe more efficient. So forth and so on. Basically, if the first was good and you can get it for cheaper, I would just go that route..
I don't think I would say this ^^^^^^^^^^^^^^^.
7K2d, while similar in the way the amp works, is a single PC board, rather than 2 4kd's (or whatever, 4k6ds?) strapped inside like the old 7KD model.... I would stay 100 miles away from a 7KD unless it's in pristine condition and has never been used by a dBDrag Street A,B,C, or Street Max guy ever....
If I was to use a 7KD in a vehicle, I would make **** sure it was fused properly and NOT push it passed it's limits. If you used common sense and a little restraint, it would probably make a nice 4-5KW daily beater on 14.4V.
The 7K2D is fine for whatever, just make sure with either amp, you have several batteries and good voltage in the 12-16V range and stay within that range if at all possible. 1 ohm is fine with the 7K2D, not sure on the old 7KD, maybe better at 2 ohms....
can you expect more power daily out of the 2d than the old one?
I don't know for sure, but I think they should be similar for sure. I think the 7K2D would be much more reliable and less touchy to low impedances than the 7KD, but I really haven't played with either amp enough yet (too busy here) to tell you for sure.
There ya go! That's more than I have had time for testing for sure. For the record, I like the 7K2D, but I don't really like the 7KD. Not based on performance, but based on what it looks like inside, as I have to fark with them....
kylediablo
17 & certified
kylediablo
chatham, il.
krankster
