Sold SQ'esq substage oldschool cheap
infamous_e46
hArRy_DaNgLeRs
pair of kicker x15c's
alpine mrv 1507
both look good for their age and perform even better
520 shipped conus o.b.o
for 575 shipped conus o.b.o ill throw in the 65ah batt new never used
kicker specs
600wrms each
91db sensitivity
frequency response 23-500 hz
mounting depth 7 inches
alpine specs
Alpine Mrv 1507
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 150W, 0.08% THD
Per channel into 2 ohms .......................... 300W, 0.3% THD
Bridged into 4 ohms ................................ 600W, 0.3% THD
Power Output: RMS Continuous Power (at 14.4V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 225W, 0.08% THD
Per channel into 2 ohms .......................... 450W, 0.3% THD
Bridged into 4 ohms ................................ 900W, 0.3% THD
Max. Power (at 14.4V)
MRV-1507
Per channel into 4 ohms ............................................ 450W
Bridged into 4 ohms ................................................ 1500W
Frequency Response ................... 10 Hz to 50 kHz (+0, –1 dB)
Signal-to-Noise Ratio
(referenced to rated power) ........................................ 105 dBA
Slew factor ........................................................ Greater than 5
Damping factor
MRV-1507/MRV-757 ................................ Greater than 500
MRV-F407 ................................................ Greater than 100
Input Sensitivity (for rated power
output) ........................ 200mV to 4.0V (1.0V at center detent)
Input Impedance ....................................... Line in: 10k ohms
Speaker Impedance ............................... 4 or 2 ohms (Stereo),
4 ohms (Bridged)
Active Dividing Network Frequency and Slope
MRV-1507/MRV-757 .......................... LP: 30 Hz to 200 Hz,
24 dB per octave (MONO)
HP: 30 Hz to 200 Hz, 12 dB per octave (STEREO)
MRV-F407 ............. 50 Hz to 400 Hz x 20, 12 dB per octave
Power Requirement .................. 11 – 16V DC Negative Ground
Dimensions (W x H x D)
MRV-1507 ............................... 260mm x 60mm x 530mm
(10-3/16" x 2-3/8" x 20-7/8")
MRV-T757 ............................... 260mm x 60mm x 330mm
(10-3/16" x 2-3/8" x 13")
MRV-F407 ............................... 260mm x 60mm x 330mm
Weight
MRV-1507 .......................................... 8.8 kg (19 lbs. 6 oz)
MRV-T757 ......................................... 5.2 kg (11 lbs. 7 oz)
MRV-F407 ........................................ 5.3 kg (11 lbs. 10 oz)
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
infamous_e46
