SQ and SPL subs plz
SQ subs - Partsexpress is selling Dayton RS HO and HF 12" on sale for around $115. Best SQ subs available for the money PERIOD. Another bonus is that the HO subs also only require VERY SMALL boxes for their size. If you don't need to compete just get 2 or 3 12s and port it tuned prettty low. Should get plenty loud enough for daily listening with excellent SQ.
Yup!
i have always heard that the 10" version is "better" though.
I just found someone who will sell me 2 Soundstream Reference RFW-10 10" together for $170 shipped. Is that a good deal? Here are the specs:
Pair of Reference SQ 10" Subwoofers
1000 watts peak output per sub
500 Wtts RMS Rated with real world precise ratings per sub
Cast Aluminum Basket
UDV Cooling Technology
Fiber Glass Cone Eliminated distortion and un-wanted noises
Black Progressive Roll Conex Spider
C-Lock Rubber Gasket
XLS Santoprene Surround
Dual 4-ohm Voice Coil
2.5" Aluminum Coil Former
Woven Tinsel Leads
Vented & Extended Pole Piece
Low Carbon Top & Bottom Plate
Rubber Magnet Cover
2.5" inch voice coils
100 Oz big magnet
Frequency Response: 23 HZ - 1.4 KHZ
FS: 28.5 HZ
QES: .492
QMS: 7.969
QTS: .464
VAS: .8575 - 25 cubic Liters
XMAX: .649 inches
SPL: 85.87 DB
Mounting hole: 9.5 inches
Outer Ring size: 10" inches
Mounting Depth: 5.4"
Recommended enclosure: .5 - .75 cubic feet
Recommended to use with sealed enclosure
One Year Warranty
Get a W7 or the new SI mag if you want "a sub with high sq but competition-level spl"
Those soundstream are an ok deal but 2 10" is not comp level SPL subs by any means.
15" CVR or something with some cone area that will still sound good, Mach 5 audio MAw or MJ series for your budget.
I think the new Si mags are going to be more SQ oriented with lower power handling. Probably will get loud but not "competition level spl."
Someone correct me if I'm wrong.
killdevil fox
killdevil fox
Pumkin Peak, Appalachia
tsenfw
