SPX-17PRO burned
HNaga
after wiring SPX-17PRO to PDX-5 , 5 minutes and right door tweeter had no sound
I turned the HU wihich is CDA-9887 off , checked what happened I found the woofer became solid .
I found that the guy who installed it , put + in - and - in +
I was surprised , is that the high quality of Alpine , where is the protection.?
Any way . what to do now?
after wiring SPX-17PRO to PDX-5 , 5 minutes and right door tweeter had no sound I turned the HU wihich is CDA-9887 off , checked what happened I found the woofer became solid .
There's your problem.
The "quality" of alpine is gonna be just as good as your install. I've run alpine amps, so i have no complaints of their quality.
That sucks pretty bad, but i'd go talk to your guy who installed it. See what he may have been thinking.
what should I expect from him? make international order and pay 500 USD?
the problem is I can not even get the tweeter and the woofer as spare parts
they are both discontinued in Alpine Parts site.
should I contact Alpine support?
That would be out of phase.. nothing more..
I have 300wrms to mine from a JL HD600/4
check tuning..
That would be out of phase.. nothing more..I have 300wrms to mine from a JL HD600/4
check tuning..
I hope so , but I think the tweeter is physically damaged , I checked it with DMM
and switched the left and right tweeters
and although the ohm of the woofer is OK , I can see the difference between it and the left woofer , I can not see any move from it.
yes there is low sound but no as the right one.
what else I can do?
I hope so , but I think the tweeter is physically damaged , I checked it with DMM and switched the left and right tweeters
and although the ohm of the woofer is OK but I can see the difference between it and the right woofer , I can not see any move from it.
what else I can do?
do you have a tone genorator?
you checked that the speaker plays out of the door but not in the door?
PDX may have clipped & blown the tweeter..
disconect the mid from the xover & see if the tweet plays..
then try the tweet pulled & see if the mid plays..
also check the Jumpers to see if anything is misplaced...
check dB settings on mid & tweet
keep us posted..
no.
woofer is playing but low sound and not detailed as the left one.
PDX-5 is set to 0 db for all.
All I did , is I took the damaged tweeter and put it in place of the left (working one) and it didn't work too.
Jumpers are as they were when comp came , both jumpers are in their place.
tweeters setting in the corssovers are both 0 db
I changed only the phase jumpers left is set to 4 and right is set to 3
the first time I played after installation , there tweeter was producing strange sound with the music something like clicking , chack chack.
I reduced the sound to 10 in HU for 5 minutes and switch the car off.
after 2 hours I tried again and there was no sound from the tweeter.
I think if something wrong in the corssover , the tweeter should work with the other corssover.
However I can not imagine what had happened , i think it's a short. but I think that the tweeter protection should work then.
@troy_audi0
I got them from DiscountCentralOnline‏ through Amazon.
I contacted them and will see what will happen.
@Trey803:
what may burn them? I really want to know.
HNaga
HNaga
Cairo
HNaga
vegang
vegang
